forming loops
I’ve a flat piece of geometry that I want to use to create loops and straps on a character. I’ve used GoZ and bend deformers/lattice shapes in Maya for some of the larger curves, but I’m stumped on smaller, tight loops such as these…
Moving the vertices in maya wrecks the topology, and I don’t seem to be able to get any kind of fine control using move and rotate in zbrush…
Transpose and the move brush would probably be the likely options in zbrush. In Maya you could create a new model so that you don’t have to worry about ruining the topology. Extruding it along a curve would probably be fast, and then just import and append it to your sculpt.
yeah I managed to get a reasonable result using the transpose ‘bone’ posing mode. I want to avoid making new models for everything as I’ve created the flat ‘strap’ with a nice constant thickness and a webbing texture (actual geometry not image) applied with the layer brush. I struggle with thin geometry as it is and I imagine I’d have terrible trouble trying to get the texture onto a thin, curved surface evenly.
I suppose it depends on your workflow. I like new objects as I can easily give them a new set of UVs, along with noisemaker for the surface texture. Then I start merging once the bulk of the work is done.
Backface automasking can be a life-saver with thin geo.
with something like a nylon strap it seems easier to me to UV and texture it first, then bend and twist that as needed.
as for noisemaker, I can’t get anything useful out of it at all… I’m not sure why I find it so confusing either :confused:
