'Floor'
Hi.
I have a model with subtools I would like to alter in Maya.
When I ‘GoZ’ I get a result where the model is 90 degrees from horizontal and when I turn on ‘Floor’ in ZBrush it is also 90 degrees off. How can I correct this?
Thanks!
~S.~
http://docs.pixologic.com/reference-guide/preferences/importexport/
If I understand you correctly and your model is wrong in both ZBrush & Maya then you can correct it by:
  1. Using Tool>Deformation>Rotate to rotate one subtool by 90 degrees on the appropriate axis (click on the little X, Y or Z on the slider).
  2. Press Tool>Deformation>Repeat To Other to carry out the same action on all the other subtools.
Thanks, Marcus! ~S.~
