Prior to version 4R4 the floor was opaque when viewed from below, so that you couldn’t see your model. What you are seeing is not a bug but was introduced so that the model became visible from below the floor.
To render without the screen dots, use AA Half mode. So double the size of your document and then press AA Half.
For more control, turn off the floor and instead append a plane. Position and scale as you wish and then use the Tool>Display Properties>BPR Visibility slider to set the degree of transparency.
It’s not possible to render a scene from below so that there is a floor shadow but the floor or plane is completely transparent. You would need to use the plane method above to output separate Shadow passes and then composite in Photoshop.
