Flatten Low Frequency
Is there a tool in zbrush that can flatten a portion of a surface so that large low frequency bumps are filtered but medium and fine detail remains in tact?
This would be from a high res scan so I can’t lower the subd level. I want to be able to square up scans of some old walls without removing the detail.
Thanks,
Casey
Check the non default brushes in the lightbox .morph target,deformations then morph brush.
