Flat surface masking question
I have imported as an alpha a skull shape .
My goal is to keep the shape but get rid of the flat base ( through masking -> delete hidden ).
Is there a way to select the flat surface through the use of tools like “Mask by Cavity” or “Mask Peaks and Valleys” etc etc ?
Right now the only way I found was to mask everything “manually”. :confused:
Thanks in advance
Cheers
Vincent
Mask by the alpha image you have.
could you please elaborate ?
I mean I know how to mask and masking with the ctrl key pressed is easy but I would like to know if there’s a way to use the various masking tools/options to somehow “automate” the masking of the base ( and just keep the shape ).
Cheers
V.
If you go into the alpha menu you can invert the alpha before making your 3D object.
http://www.pixologic.com/docs/index.php/Alpha_Palette
Brilliant, I’ll try that tonight :+1:
Out of curiosity, is there a book or a tutorial somewhere explaining all the in/out of the masking options ?
Thanks for the help.
Cheers
V.
Here is a start.
