Flat Color Viewport Error
Hey guys!
I was doing some sculpting today and ran across an error that hasn’t happened to me before and I can’t quite figure out what is going on? Has this happened to anyone before and if so, what was the issue?
I tried to save it out as a ztool and load it into a new project, but had no luck.
I do not want to export/re-import every mesh if I do not have to. I am not sure if I can do so while maintaining my subdivision levels.
If anyone can help that would be great!
*EDIT: In case this happens to anyone else in the future I got some help on a facebook group. ZBHO.
Loading in a ztool didn’t work, but if you load a project (zsphere, dynamesh sphere, anything really) that is working and then load in a ztool, it fixes it.
Possible culprits would be using Render: Flat (instead of Render: Preview or Render: Fast), or accidentally using only RGB (instead of MRGB) when out of Edit mode (such as when you first draw the tool onto the image document).
