Is there a way that I can get a brush that works like flat brush in the 3d brush in 2.5 d? Sometimes I just want to flat out certain area that I pull out.
Thanks
Thanks
I can’t think of a 2.5D variant. The closest I can think of would be to use a Plane3D with Zsub active. This would truly flatten an area. Use the gyro to manipulate the plane into the desired position.
Yea… it’s not working out that well… but it’s something.
Hopefully zbrush 3.5 will have a flat brush for 2.5 D
Is that even possible to do?
Draw and enjoy.
Marcus,
That works pretty good. but when I change the orientation to vertical, I can’t get anything to happen. When I left it on the default orientation and once Z, i was able to flat the pixols out with the circle tool. But it also leaves me with a hard edge around the circle. I used the smudge brush and try to smudge it out. It’s gets pretty tricky doing it and does not always work.
Not sure why selecting the vertical orientation wouldn’t work.
You might also try the Blur Brush for smoothing:
