Hm, strange. I import an obj file, but no matter what I do, the symmetry is way off?
explain???
Is the object symmetrical?
have you tried local symmetry?
Have you tried assigning a Set Pivot?
how do think is the object symmetrical? pls explane
i try every tool about symmetrical stuff in zbrush nothing help. Problem is when i modeling obj mesh from 3dmax, one dot is on model and other is way outside of mesh doing nothing…
whaaaaatttt???
screenshots
Make sure your obj is at 0,0,0 in an external editor and freeze/reset transforms. You may also need to select a different axis of symmetry.
