(fixed) Constraining Move Brush to a line
Is there a way to constrain the move brush to a line? I know the curve mode line function will be constrained to a line but it
doesn’t give me the results I seek. Is there another modifier combination that will work?
Something that may do the trick for you is to turn off Transform >> Modifiers >> Xyz. You can then turn on any combination of the adjoining switches. Doing this will restrict your brush to only operate along the specific axis that you’ve specified.
Good catch, I indeed had radial sym on. Thanks
Well, that was symmetry. What I was talking about is something a bit different.
Transform Symmetry mirrors what you do across a specified axis.
Transform Modifiers prevent editing except along a specified axis.
Each is capable of being turned on and controlled separately.
Excellent, that works wonderfully. Thanks
