// Here you will find 20 Useful Shortcuts!
//NOTE!! There are more helpful ideas in post #4 of this thread.
// Here we have new shortcuts for +&- of four sliders, Focal Point,
// Draw Size, ZINtensity and RGB. The keyboard number supplies
// most of your sculpting brushes.
// The sliders are all within the left hands reach.
// To install this script download the attached TXT File and place it in the
// following folder:
// Pixologic\ZBrush2\ZScripts
// Then load it any time you want from the ZScript pallet. Zbrush will
// automatically generate a ZScrpt .ZSC file in the same folder leaving
// the .TXT file for future referance.
// Alternatively if you want this to load everytime you run ZBrush you can
// place this text file in the following folder; NOTE you may need to create
// the ZPlugs subfolder yourself first:
// Pixologic\ZBrush2\ZStartup\ZPluges
// Zbrush will automatically generate a ZScrpt .ZSC file in the same folder
// leaving the .TXT file for future referance.
// Then after running this script from the ZScript pallet the first time; it will
// be available every time you run ZBrush without the need to execute it
// manually. You can confirm it is running by trying the short-cuts and or
// viewing the new “Sliders” SubMenu in the ZPlugs pallet.
// These are handy if you want to drag and drop the buttons
// around the interface, but simply using the shortcust on the keyboard is
// the more efficient route most of the time.
// If you haddn’t already made a Startup\ZPlugs directory, now would be a
// good time to create it.
// I hope you enjoy this ZScript and find it quite useful.
// Feel free to use all or some of this code in your own ZScripting adventures.
// As is standard practice, understand that your use of this ZScript
// is at your own risk and I take no responcibilty for it and or this scripts
// use by you or others.
// The chart below details the key assignments. Have fun!
// A big thank you goes out to EZ for giving me a couple pointers,
// and for provideing so many useful ZScripts. Also Thanks to this friendly
// supportive community of inspiring artist. And lastly I say thank you to the
// people of Pixologic for making such a dynomite application.
// Stephen Casey
// Std Key 8
// Std-Dot Key 9
// Inflate Key 5
// Inflate-Dot Key 6
// Morh Key 2
// Morph-Dot Key 3
// Layer Key o
// Smooth Key p
// Pinch Key 4
// Nudge Key 1
// + Key b
// - Key n
// Focal Up K
// Focal Down Alt+K
// Draw Up J
// Draw Down Alt+J
// ZIntensity Up L
// ZIntensity Down Alt+L
// RGB Up U
// RGB Down Alt+U
[ISubPalette,“Zplugin:Sliders”]
[IButton,“Zplugin:Sliders:Focal Shift UP”,“Increases Focal Shift by 1 units”,
[IFreeze,
[ISet,Zscript:Show Actions,0]
[ISet,Draw: Focal Shift,[IGet,Draw: Focal Shift]+1]
, ‘k’]
[IButton,“Zplugin:Sliders:Focal Shift DOWN”,“Decreases Focal Shift by 1 units”,
[IFreeze,
[ISet,Draw: Focal Shift,[IGet,Draw: Focal Shift]-1]
, Alt+‘k’]
[IButton,“Zplugin:Sliders:Draw Size Up”,“Increases Draw Size by 1 units”,
[IFreeze,
[ISet,Draw: Draw Size,[IGet,Draw: Draw Size]+1]
, ‘j’]
[IButton,“Zplugin:Sliders:Draw Size Down”,“Decreases Draw Size by 1 units”,
[IFreeze,
[ISet,Draw: Draw Size,[IGet,Draw: Draw Size]-1]
, Alt+‘j’]
[IButton,“Zplugin:Sliders:Z Intensity Up”,“Increases Intensity by 1 units”,
[IFreeze,
[ISet,Draw: Z Intensity,[IGet,Draw: Z Intensity]+1]
, ‘l’]
[IButton,“Zplugin:Sliders:Z Intensity Down”,“Decreases Intensity by 1 units”,
[IFreeze,
[ISet,Draw: Z Intensity,[IGet,Draw: Z Intensity]-1]
, Alt+‘l’]
[IButton,“Zplugin:Sliders:RGB Intensity Up”,“Increases Intensity by 1 units”,
[IFreeze,
[ISet,Draw: RGB Intensity,[IGet,Draw: RGB Intensity]+1]
, ‘u’]
[IButton,“Zplugin:Sliders:RGB Intensity Down”,“Decreases Intensity by 1 units”,
[IFreeze,
[ISet,Draw: RGB Intensity,[IGet,Draw: RGB Intensity]-1]
, Alt+‘u’]
[IFreeze,
[Isethotkey, 1072, ‘8’]
[Isethotkey, 1073, ‘9’]
[Isethotkey, 1074, ‘5’]
[Isethotkey, 1075, ‘6’]
[Isethotkey, 1080, ‘2’]
[Isethotkey, 1081, ‘3’]
[Isethotkey, 1076, ‘o’]
[Isethotkey, 1077, ‘p’]
[Isethotkey, 1078, ‘4’]
[Isethotkey, 1079, ‘1’]
[Isethotkey, 4359, ‘b’]
[Isethotkey, 4360, ‘n’]
[Isethotkey, 4361, ‘,’]
// End of file. NOTE!! There are more helpful ideas in post #4 of this thread.
