Hi SNARK,
I’m glad you like the plugin but I’m sorry you’re having problems.
I wonder whether you’re switching on the ZBrush ‘sticky key’ feature by accident and this is causing the problem. This can happen when switching between Alt, Shift and Ctrl sometimes and means that the Shift or Ctrl keys get ‘stuck down’. You can tell that this has happened because your cursor will be blue or yellow even when no keys are pressed. To get rid of it just press the Shift (for blue) or Ctrl (for yellow) keys. [Press Shift, press Alt, release Alt, release Shift to see what I mean.] Note that if the Shift key is stuck down then pressing any of the plugin view buttons will always STORE not retrieve settings, so mucking up your project.
If this isn’t what is causing the problem then I’m afraid I’m at a bit of a loss. The plugin only takes control of your model when you press a plugin button - to store or retrieve a setting. Otherwise ZBrush is in control. You might try using the gyro to position your model. As long as you switch on Edit before storing a view then you won’t have any problems.
HTH,
