I imported a mesh from maya and find certaiin areas where there are holes in the mesh. How might I fill these holes, in Zbrush? I am using 3.1.
I’ll let someone else describe the best way to clean up the mesh, but I just wanted to chime in to say that n gons are displayed as holes in ZBrush. So if you have polys in your mesh with more than 4 sides, it will not work correctly.
Thanks for the reply. I imported a mesh from maya and then reworked the mesh in maya and imported it again and fixed the hole problem but I would like to do it in Zbrush.
I just found a tutorial at house of tutorials, zbrush season 1 on filling holes. He goes pretty fast but it shows how to do it.
Version 3.5 R3 has a remesh function which can be used to fill holes.
Hello,
can you please show me the tutorial about filling holes in ZB …be cause i have sculpted and painted the model in the end i see hole so any suggestion what i can do…Thanks
