File Write Error Zbrush R5
My system drive has 57gigs left of 250 - why does it tell me that there is no space?
the temp folder is located on this drive, as well as all other zbrush related folders…what is it asking me to delete, and from where?
It’s probably not the size of the file itself so much as the number of polygons in your model. How many polys does it have at subdivision level 1? Are you using a working mesh or doing the UV mapping on the original, multi-res mesh?
