file write error . (Disk space critically low )
Thanks for looking out ! I got problem when I was trying to open zbrush 2019 there comes error saying disk space critically low but I have 129 gb free on C drive . And file error dialog box dosenr=t disapper no matter how many times I click OK . It works perfectly before but now suddenly whats wrong cant figure out . And I reinstall too but there is still problems.
Hello @Atit
Sorry you’re having some trouble!
Pixologic does officially recommend 100gb of free space for zbrush installation and scratch disk, so you’re right on the edge of that if the information you’ve given here is accurate. I don’t think it should result in your issue (though I have no experience with this situation), and shouldn’t make zbrush inoperable, but you do probably want to clear some more space on that drive if you want to use Zbrush well. The space isn’t required for storage, but to be able to work on large files with virtual memory.
Otherwise, I can offer some general advice. Installers can become corrupted. Download a fresh installer of the current version of Zbrush (2019.1.2) from your My Licenses page . Make sure to disable any anti-virus while installing.
If this doesn’t correct your issue, you should make a Support ticket, and work through the installation with them. They are better able to troubleshoot installation issues than we are here.
tnx for the info .
