Fibers preset for grass grows up and down on object [Answered]
Hey all, I’m trying to have grass along a plane for a scene I’m doing. I masked the area and apply the grass preset but it grows grass both out the top and bottom of the plane. It’s not a gravity thing, because if I adjust the gravity it reduces the grass height, but it still pops out of the bottom with the same reduced height. It’s almost like it’s mirroring the fibers, but I’m not sure why… I thought it might have to do with the fact that it’s a plane instead of a flattened cube… but not sure if that would make a difference…
If you are going to use a Plane, make sure ‘Double’ in ‘Tool>Display Properties’ is turned off before you press the ‘Preview’ button in ‘Tool>FiberMesh’.
As zber2 says (thanks zber2 :slight_smile: ), if Double is on in the Tool>Display Properties then the fibers will preview on both sides of the mesh.
Thanks Again!
