fibermesh leaves and scale
Having some issues trying to create fibermesh leaves and making the strands perfectly square. I understand the relationship between the length and the coverage should give me a perfect square but the scale of the object ends up being so small by the time the proportions are set.
Most of the time the coverage is maxed out at 5k and I have no where to go to get it the size I want. I can resize it up with the bpr render settings but that doesn’t help me in getting it in to another package.
Also I was trying to set up a workflow where by I would create one detailed branch, then use fibermesh to paint where these instances would go, and then use micromesh to instance the premade branch. The issue again is I can’t size up the fibermesh up to the size I want.
And if I collapse a subtool that is a fibermesh in to one subtool, I lose the UV’s, is there a way around this one.
