Fibermesh Export Curves OBJ PROBLEM , other export files works (.ma,..)
I cant import curves/guides/splines from fibermesh with OBJ… to 3ds max(or Maya, but it doesnt work with .obj, with .ma it works, but i need .obj because is the only export format that 3ds max read from zbrush fibermesh curves).
1- this is what im trying to export to 3ds max, a test scene that i made it. A tried with Fast Preview button check and uncheck.
Click Export Curves and select .obj
2- I open 3ds max and click import and select the FBcurves file. I tried every combination in this dialog…
3-… And always get the same message: “Nothing found to import…” 3ds max 2011 and 2012
EDIT: If i export in .ma format into MAYA its Ok, the problem seems to be the OBJ export option!! Doesnt works in Maya neither.
update edit ^
update ^… somebody try export .obj? is a bug on the last update? maybe i need re-update? please, somebody try to export as .obj and tell me about it!!!:cry:
Hi there !
I got the same problem :wink:
But unfortunately, I won’t be able to help you cuz I use Maya, so importing a .ma file is alright for me :confused:
Cuz yeah, it works if I import an .ma file in Maya. But it doesnt if I try to import the .obj (Nothing happens when I do it, and the outliner stays empty).
Sorry mate ! :confused:
But i’m interested aswell about importing a .obj curve file in Maya/3DS … If someone got any news or tricks for this…
Thanks
Cheers,
Lad
Hi there!
Any update about solving this problem?
I can’t import the curves into 3ds Max 2020.
I got it with Maya 2015
You can try and enjoy the day !!!
