FiberMesh even distribution?
Is there a setting or a way to control and evenly distribute Fibermesh fibers? It seems that they are always randomly distributed across a polygon. Is it possible to have them located exactly from the centre of a polygon or from a vertice in order to get an exact even distribution?
I am not aware of any way to control that at this time.
You could perhaps work around things by using masking to define the specific places where you want fibers to appear. You’d basically make a copy of the support mesh and subdivide it (with Smt turned off) to have enough polygons for the masking that you need. Once you have generated the fibers and accepted them, you could then delete this copy.
