I cant import any file in fbx format with the new r7 plugin…my zbrush every time crash…
Anybody can help me…
What happens if you export a model as FBX from ZBrush and then re-import it?
I exported a demo head and then reinported…all gone good…
Perhaps the other file tahat intried to import were incompatible…i think that fbx plugin is ok, right?
thx
It sounds like it. If you can upload the file somewhere I’ll take a look and try and find what the problem is.
i zipped a file…it’s ok for you?
Yes, that’s fine. I can confirm this crashes ZBrush for me too. I’ll let you know just as soon as I’ve found out why.
Ok thx a lot…
Well, this is something to do with the skeleton that’s applied to the shark. ZBrush should simply ignore this (as obviously it can’t use it). I need to find at what point the crash is being triggered as the plugin will need updating to handle this.
Thanks,
thx for the update…
You’re welcome. Here’s a version that will load OK:
ok thx…but i have more file with the same problem…how i can load them in zb (how do did for this one?). i must load them in another software??
If you have Maya or Max then you could load the FBX into that and then use GoZ to transfer to ZBrush.
Or you could get the FBX converter here, and convert to an OBJ before importing into ZBrush:
wow thx a lot…
