Hi ashaiad,
Your texture file does not match mine. I compared it with the original, and somewhere along the way, your image file has become lighter.
Download the original again here,
http://www.zbrushcentral.com/zbc/showthread.php?t=20310
And see if this doesn’t solve your problem.
Here’s another test for you. Change you color balance (in your file texture) to these settings:
As you can see, with a negative alphaOffset that is equal to the alphaGain, the displacement only pushes in. This is because the value range of the file is shifted in the negatve. Here, it’s shifted the same value (-12) as the gain (12), so you end up with value only in the negative range. If you shift half the amount of the gain (-6) then you will end up with values on both sides, where zero is the midpoint.
regards,
sunit
