Hello
I have a problem when I give for a example toy plastic material the Material applies to all the sub tools and when I gives Another type of material all the sub tools material changes to The same material how i can fix the problem.I have the 4R5 Version
Thanks.
Select the material you want to apply to the subtool. Turn on ‘Mrgb’ or ‘M’ button at the top. Go to ‘Color’ menu and click ‘FillObject’ button. That material will now stay on that subtool. Select another subtool and repeat. You will have to do this to each subtool you want filled with a material.
everything worked out
