Faded Spotlight Image
Hello, new to brush, I was using Surface noise to apply a texture to an object using an alpha, after applying an image to it in Spotlight I noticed the image had a transparent look to it when rendered.
Taking that same object (duplicated) and applying texture to it using the clay buildup brush with the same alpha and then applying the same image in Spotlight, when rendered, the image looks like it should, solid, and opaque?
Any suggestions as to what is going on?
Thanks, Dennis
