Eye!!! Texture!!!
Hi all. I wonder if u can help???
I have this eye texture I made which I am quite pleased with…yet it appears as in the image below.
Is there anyway of changing it to fit the sphere without modifying the texture, or do can I modify the model the texture is supposed to fit?
If so…please explain.
Thanx in advance… :smiley:
try doing this…with the texture selected go to tool>texture and hit auvtiles now it should be mapped to that texture size.
The texture is wrapping 360 degrees horizontally and 180 degrees vertically. If you don’t mind repeating the texture on the backside of the sphere, go to Tool/Texture and set HRepeat to 2.
Sven
it didnt work. Thanx alot aminuts tho for ur suggestion.
After playing around with some panels…by clicking UV Planar i got my desired look. Thanx again
