Eye part help
Hi
well i am a beginner at program zBrush and i’ve been searching a lot for videos etc. for part when you make eye in model…
so …
how do i import sphere for eye on model- eye hole.
i really want to know how to do it, so please help me.
if there are some videos or tutorials please let me know.
thank you a lot guys!
i hope you understood what i meaned.
In the Tool menu, click on your current tool (you’ll see a small view of it), select a sphere3d. Now go back to the tool you were working on (in this case the head where you want to add the eyes). Then in the tool menu, in the subtool submenu, click on append and then select the sphere3d. Use the transpose to resize and reposition.
Another option (for a different type of sphere). In the tool menu, click on load tool and search for polysphere. Then follow the other steps.
Since you said ‘eye-hole’, I assume you mean eye socket where the eyeball will sit… correct? In which case, you’ll either want to mask out the area and push the unmasked area inward using either the standard brush in subtract mode or some other way you can think of to push it in cleanly and efficiently. If you’re talking about actually making eyeballs then, there are also lots of ways to make those. Some just simply insert a sphere for each eye… And I’ve said it before and I’ll say it again… use the search function. It will help you. http://www.zbrushcentral.com/search.php?
