extruding with transpose tool not working
for some reason when I try to recreate what I have seen in tutorial vids like this one, I don’t get any geometry copy or extrusion when ctrl click-dragging the center white transpose tool node. If I am in “freeze subdivision levels” mode then masked geometry extrudes nicely as expected. When not in this mode it doesn’t work for me. is there a preference setting I need to check somewhere?
has no one run into this? Perhaps some troubleshooting suggestions?
This operation will only work with a model that does not have subdivision levels. However the Freeze SubDivision Levels button can be used to temporarily drop to the base mesh level and extrude the mesh, then return to the highest level and re-project its details.
http://www.pixologic.com/docs/index.php/Transpose_Additions
thank you so much for clarifying this point…and for the link to the docs. I couldn’t find that page even after several searches for transpose and extruding. Much appreciated.
