Extraction Subtool Bug?
I have read most of the Questions and Troubleshooting Forum, so forgive me if I missed my answer there. My Zbrush 4r6 is fully updated.
When using the extract option in subtools on the masked sections of my mesh it shows the extraction for a few seconds or until I move around in the scene. It then disappears leaving no evidence of it in the subtool pallet or otherwise as far as I know. It does not appear anywhere in the subtool menu and I can’t append it in. Please advise and thank you.
This is completely normal behaviour for the Extract function in Zbrush. If you move the piece after press Extract it desapears. Then you can tweak again the thickness and press Extract again to match your desired extrusion thickness. You have to press Accept in order to create the extraction in a new subtool. It will be created just below the original one. Even if the preview disapears, Accept button will create the last extraction showed
