Exporting OBJ, Displacement and Cavity from ZBrush to 3ds Max
Hi!
I’m a begginer on Zbrush. I’m learning using the Zbrush 3.5 version but I know that in older versions of the program the task I can’t get was done partly by the ZMapper plug-in. I have to export OBJ, Displacement and Cavity maps from ZBrush 3.5 to 3ds Max. For the OBJ option, I clicked in the Export options available in the Tools menu, but nothing happens… How can I do that? What can I be doing wrong?
Thanks a lot!
tool>export (at the top) for the .obj (the export at the bottom of the list is for the export options).
To get the displacement map out…after you generate it, it should show up in your alpha palette.
same goes for cavity.
