Hi everyone,
I’m having a problem (quite common from what i’ve been reading) with exporting from zbrush 3.1 (to do the uvs) into max9…
After exporting into max and re exporting into zbrush (using the morph switching tecn.) when i change my sub. div. level higher than 1 the mesh explodes.
I’ve tried reseting the Xforms, changing the exporting/importing options in zbrush to merge, changing the exprort options from max to poly and quad, and adding a turn to poly…
I’ve done this before in zbrush 3.0 with no problems… coincidence maybe? I’m guessing this is a problem with max’s exproting…
Any thoughts as to how to fix this problem?
