exporting displacement higher than subdiv level 3??
Alright, I tried to find the answer to this issue here, but couldn´t so im starting a new thread.
The problem is quite straight forward, I can create displacement maps when im on subdiv level 1,2 and 3, but when I chose level 4, nothing happends! when I chose level 3, I get a pretty good map, but not all the details I want.
Anyone knows what the problem might be?
Thanks!/Jimmy
ZBrush compares the current subdivision level to the highest subdivision level when creating a displacement map. That is why you cannot create a displacement map at your subdivision level of 4, you would basically be comparing the same mesh data and end up with a blank displacement map.
Creating a displacement map from subdivision level 1 will give you a map with all your sculpted details.
I got a problem with displacement mapping too!!
Whatever I do…my displacement map in the alpha box is blank…no detail whatsoever!!
can anyone please help me on this??
Thank you!
Slice
