I have an OBJ and a MTL but no BMP image when I export. How can I export where I get an OBJ for image wrapping?
Hi @batch
Zbrush will export a bitmap if you have an active texture applied when using tool > Export.
Otherwise, any texture image can be exported directly from the texture palette, or when using multi map exporter with the appropriate settings.
