Exported OBJ loses UVs in Maya
Has anyone else had this issue?
I have export out obj’s to maya with uv’s all the time. Last night was a first.
I exported a leaf obj with uv’s and they would disappear as soon as I imported into Maya. The workaround was to export as a .ma, and copy and paste into working Maya document. I would prefer not to use a workaround.
Any ideas as to why this could happen?
ZBrush will export UVs with an OBJ file if the Tool>Export>Txr button is turned on. So, you could check that. You might also re-import the OBJ into ZBrush and check the UVs. If they’re OK then the fault must be with Maya.
Thank you for the reply Marcus. I did not know the txr button needed to be turned on.
Nice to know!
It’s on by default, so it’s unlikely it’s the cause but still worth knowing about!
