Exported OBJ is split into separate meshes
I’ve encountered a big problem:
If I export my lowest subdiv as an obj, it results in multiple meshes, as if my model was split randomly.
I can’t use GoZ, as I’m using Silo.
Is there a hidden setting somewhere I’ve omitted?
Any help would be much appreciated!
Kind regards,
Patrick
Have you tries selecting the ‘Mrg’ button in the export settings?
Wow! Where is that ‘Mrg’ button? What export settings are you talking about?
I couldn’t find anything in Preferences > Importexport.
If you created the model in ZBrush, it’s possible that you have multiple Polygroups which would export as seperate elements. To check this, turn on PolyF button to see if you have multiple polygroups. If you want to join them and export your model as a single element, then just go to Polygroups submenu and click ‘Group Visible’ to join everything.
Thanks for your help.
Solution:
Tool > Export > make sure “Mrg” is on and “Grp” is off
