I know this is a basic question but i cant find the answer anywhere…
How do i export a UV map to photoshop to paint then import back in. . . ?
In Tool>Texture Map press New From UV Check, clone the result and then export from the Texture palette. If you turn on polyframes before creating the map then they’ll be included.
Turn it into a Texture Map. First select the size you want in “Tool > UV Map” then go to “Tool > Texture Map” and click “New From Polypaint”. “Clone Txtr” and export in “Texture > Export”. If you need the wireframe included then do as Marcus suggested (turn polyframe on and then “New From UV Check”).
ah yes, thank you both very much!
