What is the relationship between the scale slider in the export options and the scale slider in the deformation area? I am pretty sure they are not 1:1.
I have an issue where my model in max was out of scale with the zbrush tool. To match scales using the Export Scale Slider, I set it to 75 which matches perfectly. To match scale using the Deformation Size Slider, I have to set it to -62.975, and even then it is not pefect.
Is there a reason for the disparity?
As I build the rest of my project, I would rather not have to set all of my tools to an Export Scale of 75 to be consistent. That will introduce all kinds of production issues across the studio. How do I figure out what to set my Deformation Size on this one ztool in order to get a perfect scale match?
