Export obj with textue
HOw do you export textures that you have polypainted onto models in obj?
You can export as either OBJ or STL. With OBJ, you will need to import into a program that can read the custom polypaint tag, such as ZBrush or XNormal. STL should be OK with any program that can import it.
To export OBJ:
Press Tool>Export and save the file.
To export STL you use the 3DPrint Hub in the Zplugin palette:
Press Zplugin>3DPrint Hub>Export to STL. Make sure Polypaint is on in the Export Options.
