Export Import Nightmare(scaling)
So I have three mesh objects in my subtool. I export one, import it back, and the mesh has dramatically scaled down. I don’t even do anything to the mesh other than exporting and importing it back. My export scale slider is set to 1, everything seems to be set just right. I don’t even have to add it to the subtools to know that it has scaled down, I can see the size in the ztools palette. Any thoughts on what’s causing this?
The Fix: Make sure you have the first subtool selected, then go to export(under tool), and set scaling to 1. Every subtool has its own export scaling option, and I had the last subtool selected when I was changing the export options. And apparently the first one annuls/overrites the export options for the rest of the subtools.,…
