Export history as OBJ sequence
Is anybody out there interested in writing a script/plugin that can export the entire history as a sequence of *.obj’s.
My current workflow is painfully slow and involves exporting a normal state - morphed state - followed by a re-dynamesh and a repeat of the first procedure. Once I’ve done this 20 times, I have roughly 3-4 seconds of animation. So you can see the problem I face. The manual way also limits the creative flow of the model. With a script/plugin, I could potentially work from sculpting point A - export the 200-300 steps and then animate that as a referenced sequence in my host application.
Would be really pleased if somebody could help out in this department, as it opens up a lot of creative potential.
Cheers.
It not too difficult to write a macro that does this. Save the file to your ZBrush 4R6 /ZStartup/Macros/Misc folder and press Macro>Reload All Macros. You should then have a new button Export History OBJs in the Macro>Misc sub-palette. Press the button and you’ll get a Save As file dialog. Give the file a name and the sequence will be saved out with numbers automatically added.
Download here:
Thanks Marcus :+1:
Thanks Marcus. Will give it a try now.
Worked like a charm. I appreciate you helping out as quickly as you did. Thanks again.
Great! :slight_smile:
This is such a cool time saver script for exporting multiple morphs in obj format, thank you.
I will poke at the script to see if I could do the same for FBX…
I’m afraid that won’t work because you can’t run two scripts or plugins together.
Hello Marcus! its been 13 years since this message but im trying to do the exact same thing but I cant find any macro to download anywhere in the internet and I was wondering what happened with it, as in your message the link isnt there anymore?
Thank you in advance for the help!
