Xnormal program works good for making displacements.
I learned the displacement from zbrush from Eat 3d, I can try to sum it up.
1.In the tool settings, go to the UV map section and set the UV size for the size of displacement you need
2.create a texture map by clicking the “new txtr” button in the texture map section
3.clone the texture map. The texture gets placed in the left texture slot… if that makes any sense. Make an alpha of it.
4. Go to the displacement map section of the subtool, select the empty square and select the new texture you just created.
Hold the ctrl button and put the mouse over the buttons for descriptions what they do, make sure mode button is checked then press the create dispmap button.
cool lincoln
