Every time I try to make adaptive skin (preview or actual) Zbrush 4r5 crashes.
I’ve got a sculpt I was working on, originally from zspheres, then decided to add horns as a subtool. I made the shapes from another zphere and whenever I try to make adaptive skin, either hitting “a” or make adaptive skin, the application crashes.
Any advice?
Thanks.
I guess you’ve tried to close and re-open ZBrush. Have you tried it in a new project file?
I reported this to support and was told to make sure the software is up to date by checking Updater. That wasn’t the problem. I discovered on my own that if you go to the Adaptive Skin modifier and increase the normal setting from 2 to 4,5 it didn’t crash. When I reported this to support they informed me that adjusting from 2 to 4,5 shouldn’t have made a difference but it did. Try and see. Hopes this helps.
