Anyone know why I get an Error message: “error has been encountered while trying to load a Tool. Loading has been aborted”
While trying to load a high rez tool from my network? I have the same problem when loading a high rez Obj. but if I save them locally both import fine. Is there a fix for this yet?
First, which version of ZBrush are you running?
Second, how long is the path name of the file? There are limits.
version3 Windows xp
W:\Jobs\Films est\Suits\Steve\3d\Z\Ztools\Steve\Body\Body_v01.ztl
Is there really a space in the B ody folder name, or is that a typo? If that’s a space, try renaming the folder to remove the space and see if that resolves the issue.
no there is no space.
I’m curious – why are you running ZBrush 3 instead of 3.1? That may be the cause of your issue. Version 3 is no longer supported. You should install 3.1 instead. Please contact http://suppport.pixologic.com for instructions.
