ERROR MESSAGE #540 can't save anything
I’ve been happily using ZBrush for some time now and today when I tried to save my model I got an Error message #540.
It reads INTERNAL ERROR AFile.cpp Line:540
unable to open/ Create a file!:confused: (then the path to the folder)
I have plenty of HD space. 79 gigs on this drive and Lots of Ram 4.5 gigs. Machine is a G5 Mac Dual 2 ghz. I’ve tried restarts of both ZBrush and the machine. I have tested trying to save models that saved fine just a few days ago. I can’t even save the built in star tool as a tool. I can’t save tools, models as .obj or even the ZBrush project file. Everything was working fine until today.
Any Suggestions?..HELP!
William Dempsey
Hi All,
I seem to have solved the problem. Sort of. I tried saving to another Hard Drive and it worked. So I went back to the original project and tried saving in the original project folder. Same error. I then created a new folder on that same hard drive and it worked.
Solution: ZBrush does not like that particular project folder. Why? I have no idea, but if ZBrush wants me to save into a different folder and it will work then I’ll be happy to do that.
William Dempsey
can you save other things in that folder from other applications?
Out of curiosity, is it a local folder or a networked drive? There are often problems saving to network drives, but not to the local drive.
Hi Bill and Aurick,
I have no problems with other applications saving to this folder or the hard drive. The drive is an external 250 gig HD but not a network drive. I have been saving projects to this drive for months from ZBrush without problems.
I typically create a client/project folder and then in that folder place subfolders each labelled with the application that is producing the enclosed files. So in the main folder is labeled JANNIS _PAIN/DEPRESSION. The sub folders are labeled : AE, EIAS,Poser, SAMPLES, Skeletal Anatomy,Tests, Ref.
Then in the Poser folder is a folder named ZBrush, and Z Mods.
The ZBrush folder was the original folder I was using for the ZBrush project files. When the error occured I created Z Mods in the event that ZBrush had a problem saving to a folder that it might mistake for its own application folder if there might be an issue with that. Z Mods didn’t work either. At that point I tried other things like recent projects that had saved properly in the event it was a geometry thing. That didn’t work so this morning I decided to try another HD. I successfully saved to the system drive. I then tried the 2 folders again and got the error again. In the event it was a hiccup of some sort yesterday. I then created a new folder named “crap” on the same drive on the main level ( named so that I would remember to dispose of it after the test). The project saved to this folder. I then tested the geometry that originally exposed the problem (A Poser model that my client wanted me to see if I could make it look acceptable for the project). That saved fine to this folder as well. So there you have it.
PS… I have saved to folders inside other folders before from ZBrush on this HD. The mystery continues… :slight_smile:
William Dempsey
