I had a problem with empty alphas after importing them into the palette.
This problem has been solved by raising the Preload File Size.
The problem is now that this value is reset every time I restart ZBrush and I can’t figure out how to save the Preload File Size value so it is already set when starting up ZBrush.
Ctrl-Shift-i is not storing this value as it seems.
Any ideas?
