Hi guys, using the brush tool with activate symmetry -> radial symmetry; I’m wondering if it’s possible to “stretch” the radial symmetry in either axes to make the pattern more eliptical than circular?
The only way that might work is to temporarily change the value for the axis in the Tool>Geometry>Size slider. If you note down the original value you could reset it after sculpting.
