Edit button often not available in ZB4R5 OS X / Illustrator outlines to extrude type?
Is there a way to import illustrator curves or type outlines into ZB and extrude it precisely?
Why is my Edit button frequently unavailable? Often when I GoZ from Maya I cannot activate the Edit mode by either typing “T” or clicking the Edit button?
Why do you call the modeling clay a “tool”? The clay is not the tool, surely, the tools that work on it are??
You can’t import Illustrator curves into ZBrush, and you can read all about Edit mode and why ZBrush is how it is here:
http://docs.pixologic.com/getting-started/basic-concepts/
Thanks, Marcus! Jumping into Z Brush is like falling down the rabbit hole! All sorts of amazing things happen—often very unexpectedly. I am very impressed with the careful way everything is explained and documented. After many years with other ‘high-end’ applications, this is so refreshing. The application is truly amazing and a delight to use. Congratulations Pixologic!
Many thanks for your comments and have fun ZBrushing!
