I was working on my ztool and at one point I was supposed to make edge loops to make ears.
I was able to make the edge loops for the selected poly groups [at the lowest sub level, while selecting and isolating them], but as I move up to the sub division level I witness some weird loops or these constructs
[red and purple]
Upto sub level 3, everything is cool, but as i entered level 4, the red one got pwned and then at level 5, the purple loop.
Neither I was able to undo and I have saved the file too
Now no way back but to repair the error.
For making the edge loops I took the following steps:
- pressed ctrl+shift and then clicked on the desired polygroup.
- ctrl+shift+alt and then clicked on the poly groups which I wanted to hide.
- While the red poly group was only the visible group of polygon, I clicked on âedge loopsâ
- I got purple loops inside the red. Just to check the sub division levels, I went up and found this problem.
Please assist me where I went wrong or what wrong I did.
At Level 1:
At Level 4 [Only showing the purple and red groups of polys]:
At Level 5 [Now you can see the pwning of purple group]:
Please assist me.
Iâm using ZR2 on Quad Core Q8200 @ 2.4Ghz,
4GB DDR2 800MHz RAM,
MSI P45 Platinum with Geforce GTS 250.
