Dynamic brush off by default?
I know there are a couple threads regarding this, but is there going to be an official way to have dynamic brush off by default? right no I have to use a script for a work around every time I start up. Since I use zbrush virtually everyday, the time i spend resetting brush settings is really adding up.
not at the moment.
you can add that script to the startup zscript file or you can revert back to a previous release.
I ended up turning dynamic off for every brush that I use regularly, and then saving that brush over the original. it was a pain, but now all my brushes work like they should!
