DynaMesh Resolution issue
Hello,
Thank you for having a look.
I am sculpting a head and want to get into the details of eyelid folds, fine wrinkles and pores. Dynamesh won’t create any more active points past 5.8 million. The resolution slider is at 672. Going past this up to 4096 does nothing to create a tighter more divided mesh, although going lower will simplify the mesh. I’m not sure why DynaMesh wont do anything past 672. I created a change to the mesh to see if it was just not updating, but it does and still wont go higher then 5.8 million.
Any advice??
Also, on a side note what is the best work flow for creating a detailed realistic head.
Thanks a bunch.
Cheers, Cad
Once you get the basic form you retoplologize to the lowest res you will eventually need and repeatedly divide to the highest res and then project your dynamesh and then you do fine details such as pores and fine wrinkles. Dynamesh isn’t really designed for that step of modeling.
