Hello =)
I have a Question about Dynamesh, i have a model with many details but i need a new topology on some stretched polygon areas. so how can i make new topologys for seperated parts of a model without loosing the detail of the whole model if this is possible?
thy for answers Laslo
Clone or duplicate the mesh. Exit Dynamesh and run ZRemesher to get a cleaner model to tweak with less points. You can reproject details and color information later(it will get wiped out when remeshing). Separate parts as needed for your purposes and keep at it.
http://docs.pixologic.com/user-guide/3d-modeling/topology/replacing-parts/
you can cut the part you wanna make change as a item,after finished,use insert mesh replacement to insert this part back to your main body .insert mesh replacement can only affect the polygroup you choose to work with,no any change with other polygroup.
thanks to you guys your answers really helped me
now i can finish my work=)
