Dynamesh Problem
So I imported a pants model as OBJ, and when I dynameshed it some geometry between the legs got blended, how can I dynamesh it without this happening?, also it closes the holes inside the pants where my legs model its gonna be, so yeah… how can I fix it?
(it doesn’t let me insert images for some reason, I will put the links)
Before Dynamesh:
http://gyazo.com/dd33c751117f5cdf90b24296e3daafda
http://gyazo.com/f00e37bfde8bf998dee3a895ded22013
After Dynamesh:
http://gyazo.com/0de57691157dc905dad82c5857a8399e
http://gyazo.com/45580440fc06e3b36c83de8240c75d2c
Why do you need to Dynamesh? Subdividing will add geometry for you and won’t mess with your mesh as is happening now. You can certainly use the smooth brush to get some of your wrinkles out. :wink:
I will try to explain :smiley: also will link some other pictures
Picture 1: Its triangulated
Picture 2: Its a single object but some vertices aren’t blended.
Picture 3: Smoothing Causes the vertices that aren’t blended to separate.
Picture 4: ZRemesh Causes the same.
Picture 1:
http://gyazo.com/9267a1597a8721e3fb5359663a007188
Picture 2:
http://gyazo.com/b09f3b32bd883c2928def20298050739
Picture 3:
http://gyazo.com/70feea31319d84c3816b601e306aace1
Picture 4:
http://gyazo.com/889921fcf1e8ecb58a1526ea954d55d1
So I thought I could Fix all that with Dynamesh, which actually does, besides it generates the problem I explained in my first post D:
.obj will be triangulated. Where did it originate? There are options in the Tool:Import and Export panels (weld in Inport) Also there’s Tool:Geometry:WeldPoints Also found this>> http://www.zbrushcentral.com/showthread.php?171266-InsertMesh-Master-and-ZWelder!-unofficial-Information-Installation&highlight=ZWelder HTH
dynamesh is based on volume(scale is also important), your volume is too thin in certain areas. Remove in the inside of your mesh or inflate it and then use dynamesh. You can always do an extraction once you have a working base.
Thanks :smiley: maybe that will do!, will test it later and I tell you if I get any problems!
beta_channel:
I ZRemeshed it then Dynameshed, seems to work with very little mistakes :slight_smile: but I will try the plugin Doug Jones linked, maybe its what I’m searching for :0
UPDATE:
Pants got fixed.
