I’m trying to Boolean one object from another using the dynamesh feature and the following directions from either this…
http://www.pixologic.com/docs/index.php/Dynamesh
or this…
http://www.youtube.com/watch?v=hmCPrYD_Rq4
…gets me the same frustrating results, the two objects merge into one. The inserted mesh joins when I want it to subtract. I think the absolute best thing would be a step by step keystroke/mouse click instruction list.
DO NOT reply with “just hold ALT when inserting a mesh” because that is getting me nowhere. Obviously a crucial step is not being mentioned in both the above tutorials.
As to the “Just hold Alt” tip, the “insert mesh button” will not let me click it when I’m holding alt, only after i have clicked it not holding alt can i then hold alt when selecting the tool i wish to insert from the pop up window showing all current tools to select from. Still after doing that both combine instead of subtract.
Please someone provide a step by step keystroke/mouse click instruction as to how this can be done because I’m close to loosing my **** over this.
